KK smoother ride
jeep1350
I want more smoother ride out my KK any ideas how do this let me know thanks?
hyde
:rolleyes:
Higher profile tires (especially if you have 18" or 19" wheels) by replacing wheels/tires.
Check the PSI, and lower them to 28 to 30 psi
There really isn't much else you can do, you can also consider replacing shocks with a bit softer ones.
:rolleyes:
Lowering tire PSI will lead to outside edge tire wear and can cause blowouts.Softer shocks will cause premature spring damage and sagging.
Basically if you want it to ride like a caddy,get a caddy.It's a Jeep and should ride like a Jeep,you can make it ride firmer and be more stable but trying to make it ride softer can/will increase rollovers and unsafe stability.
jeep1350
wheels
my kk has stock 16" wheels tire size 225/75/16 I was thinking about going up to 18" wheels tire size 235/60/18 would get good handeling out that or about same as stock 225/75/16?
If it's ride quality you're looking for, that won't help. It might even make it worse. I don't know about the handling aspect of it though.:D
hyde
18" will not make it any smoother, there is less rubber to flex.
^^^Hyed is right. Leave your rim size alone. The bigger the rim, the less sidewall to flex. The only thing you might consider, is going up one tire size. You said you have 225/75/16 stock tires. If you went to a 235/75/16 you would have a little bigger footprint and sidewall.
It sounds like you should have bought a car and not a Jeep if you were so concerned about a smoother ride. As such though, you bought one of the smoother riding Jeeps. Go and drive a TJ and you will see what I mean.
Jeepin05
Cedar Rapids, IA
I am not sure if it is available for the KK, but I believe somebody has put Air Ride on their KJ.
I had this on a Buick, and the ride was incredible.
I say if you can find a way to put Air bags on a KK, go for it!
Powerslave
Pittsburgh - Come & Get Me!
The smoothest ride you get us with a taller sidewall on a tire, and full tread. If 15" rims fit, then you can use a huge tire. Going above 16" won't smooth the ride, for as larger as the rim gets, the smaller the sidewall on the tire gets. You can use the MINIMUM air pressure, and the rear tires can usually be 2lbs lower, as the weight is less back there. I also run 225/75/16, that's what it came with from the dealer. It's a jeep for a reason, and smooth ride is not one of them.
