Daylight is actually 6000k same as a camera flashI'd suggest in this order in terms of usable light.
hids with a projector mod > hids in Stock housing > 55w 9005 halogen mod In the fogs > high end halogen bulbs > leds.
I have hids I'm my headlights 5500k (diamond white) but will be going down to 4300k or 4500k because the pure white light doesn't show up well on wet roads like a bulb temperature closer to sunlight.
Sent from my SM-N910V using Tapatalk
If you read around the different sections on the site you'll see that it's not really worth it unless you'd like to have flood lights for headlights
LEDs in a halogen housing don't project down the road a lot, just out in front so they're useless
Also no company makes any sort of aftermarket LED headlights for KJs
It'll help you out if you read around, there's plenty of info
The LED's I put in my KJ far outshine(distance) then the Hella 80w/100w halogen bulbs they replaced,about twice the distance,even when pointed down(since I'm lifted so high).They should have well over twice the reach when I aim them correctly.
Any links to the product itself?
