Ok so I know on the TJ's that there was a bolt on the Spindle that I could add a washer too, which would limit the turn in of the wheel. To eliminate rubbing.
Does this exist on the KJ spindle or somewhere else?
Just got the suspension finalized and had it aligned with some new tires wound up with 245/75R16 Goodyear Duratracs.
I get a bit of rub when backing up to the passenger (Steering wheel to right) front drivers tire on sway bar. However this doesn't seem to happen when going forward.
On another note, I'm thinking something is odd with the alignment.
Either way I think I'm gonna run it back over to the shop and just have them double check.
Front has ARB 2927 Springs, new Upper & Lower control arms, bushings, ball joints, bumpstops. everything replaced except tie rod ends. I did space the clevis mount about 3/8-1/2" down from the bottom of the shock to help level it out. Both sides are even 22 1/4 inch I believe from bottom of fender flare to center of wheel on ground.
Thanks for any feedback.
- Drives good at speed no noises.
- When turning at speed it seems a little touchy (fast reacting).
- Seems like a touch of bumpsteer.
- Looks like there is a bit of Positive Camber on front.
