I agree that you will want to look at PCM programming to change timing, to take advantage of any drastic changes. But the fact remain that if you increase flow in and out of a motor you get more power. Small modification such as intakes and better exhaust might not warrant a PCM flash, and probably not major power gains but they do help. In fact I just buy better gas and see a slight improve it. No I don't know the numbers and it's not a wheelie popping monster but the fact is my gas mileage went up and I down shift as much for the hills. My point was that he was looking for performance gains and everyone seems to think there is nothing you can do. But slight changes like intakes and throttle bodies will make a difference just not sure if they will justify the cost is all. And the PCM measures the air in and add fuel to meet those needs so unless you have drastically changed something the stock PCM should keep up with slight modifications.
Well, probably the concept of 'closed loop' is a tough subject, but the bottom line is that the 'system' i.e sensors such as
IAT,TPS,O2S,etc., PCM and actuators like the injectors, EGR (does not apply to gas KJs) interact to maintain a given output,
not HPs but a pre-calculated combustion ratio, which represents the 'Required Output' of the system....
The 'system' will always try to 'keep-up' with it's own parameters, and any change made to the incoming air/gasoline flow
won't necessarily result in an increase in HPs output (though this might just eventually happen).
Anyhow the whole loop is not 'tight', therefore corrections cannot be made instantly, that's (among others..) the reason why
O2S sensor voltage, which represents the feedback, keeps on varying and will never stabilize itself on the 'goal value'...
IMHO money could be spent elsewhere ( sorry for the OT, but as everyone knows I'd buy spare parts
but that's just me...)
Ouch, I'm beginning to speak like an old man.....again :happy175:
