Don't know about the rear, but here is the front instructions -
1.Install the hub/bearing assembly to the vehicle.
2.Install the three mounting bolts (1) for the hub/bearing. Tighten the bolt to 130 Nm (96 ft.lbs.).
3.Install the axle shaft nut. Tighten the nut to 135 Nm (100 ft.lbs.). (if equipped with four wheel drive)
4.Install the wheel speed sensor to the hub. Tighten the bolt to 13.5 Nm (10 ft.lbs.) See: Brakes and Traction Control\Antilock Brakes / Traction Control Systems\Wheel Speed Sensor\Service and Repair\Front Wheel Speed Sensor - Installation.
5.Install the disc brake rotor See: Brakes and Traction Control\Disc Brake System\Brake Rotor/Disc\Service and Repair\Removal and Replacement\Brake Rotor - Installation.
6.Install the disc brake caliper adapter. Tighten the nut to 135 Nm (100 ft.lbs.) See: Brakes and Traction Control\Disc Brake System\Brake Rotor/Disc\Service and Repair\Removal and Replacement\Brake Rotor - Installation.
7.Install the tire and wheel assembly. See: Wheels and Tires\Service and Repair\Removal and Replacement.
