Looking to get a new front bumper
jharrisliberty
Colorado
I am looking to either swap out the current stock bumper for one with a winch plate or a way to attach a winch to the front of my 2006 KJ. I am leaning more towards replacing the front bumper. I have tried looking online for different options and the one that seems to keep popping up is the ARB bumper and it cost a little more than I can spend on something like this at the moment. I am on a budget and looking for good options, please help.
Welcome to the forum James.
The detour's is the best least expensive way of properly mounting a winch.
I want to also make you aware that the extra weight will make your front end sag bad!
The stock OEM springs are not designed for extra weight & will sag.
By adding the 70 lb pushbar, on stock springs I could not get 2-3 fingers between tire & wheel well!
Needles to say a full suspension lift was in order using 927 HD OME springs etc..
54802[/ATTACH]"]
jharrisliberty
Colorado
54804[/ATTACH]"]
So do you think that I would be ok if I already have a 2.5" Daystar Lift kit on it or would I still need to replace the OEM springs?
^ That's good you added your KJ year and a Daystar lift!
I suppose you could install the Detours and see how it drives, but nothing beats a good handling KJ with a true suspension lift !!
If you are thinking winch, obviously you want to use the KJ off road.
I don't think coil bind is something I want to experience....
Tom is more qualified to elaborate about Daystar and I'm looking forward to his input! :)
NO
full spring lift only forget spacers
KJ springs are weak to begin with
After all of these years you have already sagged 1/2 to one inch
so adding more weight in front you'll be at below ground level in no time
ARB makes a great bumper, couple of other options as well out there will show you some pics tomorrow
4x4kayak2112
tx
Go with OME 927s, My wifes KJ (pictured) has the Ironman C springs, and they are now sagged 1.25" since I got them new.
But for a bumper its either ARB, Backbone, Local Custom, or Mine that I make. But shipping is gonna eat you alive.
Dont ask about the bumper on the camouflage KJ. I will not make one like that for anyone else.
Sent from my SM-N900P using Tapatalk
I like my Backbone the best out of all the bumpers. I actually like the look of a stock bumper with the winch on it. I think getting a good quality, American made winch is more important that the bumper it mounts to as far improving the functionality of the Jeep.
Jim McClain
Teh REAL No. CA
Has anyone tried to fit an after-market bumper made for a different model Jeep? Seems like modifications could be made to fit a bumber like this, for instance (just something I saw in a Jeep mag, not something I researched the quality of yet):
That might open up the options considerably. Is that a possibility?
Been tried but looks like crap most of the time :shrug:
all of the wrangler bumper are made for straight across grills, unlike the earlier KJs .
4x4kayak2112
tx
Hang out on instagram. There are some on there and they look terrible.
Never been on instagram:happy175:, figured it was just a worse version of Facebook
instacrap and fecesbook
jharrisliberty
Colorado
NO
So when I am able to put new springs on (which will be before I put on a bumper or winch) will I still get the same amount of lift as I do currently from the daystar lift? And are there any other options that have not already been shown on this thread?
Doing a full spring lift you can get more lift than with a Crapstar
More lift, better ride, better handling , won't cause parts to wear out quickly etc
Not sure if I mentioned or not the Matrix brush guard ( yes it does have the option to have a winch )
Its on my 2003 currently
same one when I ran it on my 04
How does the winch mount on the Matrix? On top (in front of grill) I presume? As much as putting a winch into a bumper makes sense to protect the winch, it seems to me it would make it a lot harder to respool the cable properly and to keep an eye on it. Thoughts on that?
Just seen a couple of " spy photos" :shrug::icon_lol:
But goes into the hitch that is on the 02-04s, then bolts to the front brackets
and yes it does hamper the ability to make sure the cable is rolling on right in a bumper like ARB is
