Major fluid leak on my ‘10 KK
Jarhead
Within a few days a slight rubbing sound underneath the KK turned into a definite clicking sound so I crawled under front. I find fluid all over everything but can’t see where it is coming from, so I pull the grill and headlights. Back of drivers side headlight has fluid on it and all over engine compartment behind it. Looks like possibly a transmission cooler line along right side of radiator but curious what the hive mind thinks.
What color is the fluid? Is your radiator coolant still where it is supposed to be?
If it is ATF, it could be either from a transmission cooler line or from a power steering line. Power steering uses ATF+4 too.
