Mr. Gasket Wheel spacers
LibertyOrDeath
I was wondering about the Mr. Gasket wheel spacers. I've got a very slight amount of rubbing on my sway bar at full lock and I've been looking for a fix. I've got plenty of room on the pinch weld. The spacers come in 7/32, and 7/16. If I put these on which one would work best, and will they damage anything?
t2raz
Queens
what about wheel adapters? i heard they work a lot better.
LibertyOrDeath
It's more spacing than I wanted. The Spidertrax adapter is 1.5". I don't want to transfer rubbing from one area to another. That and the Mr. Gaskets are under $10 per wheel. As opposed to $50 or more per wheel.
t2raz
Queens
Pls. show get pix of before and after. :D im planning to get my rear wider. and leave the front as it is.
those are cheap, they can crack, and the wheel will come loose, you could always put them on and not drive it! I would not want to ride in it with those
