Hey, Everyone.. Hope the Holiday was good to you and yours... I've got a 2004 3.7l 4x4...bought the Penguin about 4 months ago. Within a few days, 02 sensor code popped up, and then went off within a couple of days... Then came back on, followed by 7 other codes. I researched all the codes as much as possible, and started with the mass flow sensor, and the little filter (which was disintegrating) inside the air box, to the right. All codes went away... Until the O2 came back.
I replaced the 02 (OBDll kept saying that was the first line of repair), and code went away for a couple of days, and then... Yup... It came back. But different sensor and bank. Now it sort of bounces around between the banks and sensors...
So far, I've replaced all 4 of the O2 sensors, mass flow sensor, mass flow filter, pcv valve and hose, plugs, ECT, thermostat, fan assembly (went out a few weeks ago), water pump, and serpentine... Coming back from a trip out on Hwy1 this past week, I suddenly realized that the engine/****** sounded to "high"... Similar to having turned off the OD (which I hadn't re flat ground)... Although not officially in "limp" mode, I stayed under 40mph to get out of the Altimont Pass (California), to get to some place where I could easily get help. Got towed back home, and now I get the P0176, P0700 and P1776.
Reading up on the P1776, my initial thought was correct, as it sounds like it's stuck in second gear... The other things that she's always done is, stick when shifted... Like shift isn't going all the way (key gets stuck on ignition sometimes, and I have to give an extra nudge into park, but goes slightly past drive sometimes and has to be nudged forward)... Other thing is that if I'm coasting in traffic, and give her a little gas, there's a clunk... but only only when the check engine light is on...sometimes louder/harder than "normal"... But engine wise, and cruising down the road, she's totally smooth... Highway, I'm getting around 21mph, and able 18 in the city!
I actually have the TCM/PCM on my list for possible replacement... The shop I take vehicles to, when I can't do something myself, or my SIL isn't available, said the PCM could be shooting out false codes, particularly as they are so random, and can disappear as fast... Anyone else have this issue??? Resolution if you did? Is it "smart" to just replace the TCM, and is this just a piece of the PCM itself, or are they two separate, but connected pieces (when I look up the TCM, it always gives me the PCM)? Any help is appreciated! Loving my Penguin, and looking to trick her out a bit for some adventuring, but can't figure this out... TIA! p
