OscarERead
Good afternoon to all, I have a 2008 Liberty 4x4 trail rated.... I live in st.kitts therefore all has to be self repaired or given to a clueless dealer which has no experience en jeep they have the dealership since 3 month ago ......anyhow, this is how my nightmare started.....
driving jeep realize there was no power, would not go over 40 miles a hour and sounded like bogging, like you had a lot of air coming in the intake but no power, climbing hills.....not a chance...., wife kept on using the jeep until a day she reached home and it wouldn't start........I ordered the BlueDriver in order to diagnostic ...it said caMshaft sensor bank A, i ordered a aftermarket one on amazon, a week later installed the sensor and nothing
Reading some posts i decided to order a crankshaft sensor and camshaft sensor all oem...installed and nothing.....
as it didn't wanted to start ordered coil packs and spark plugs.....and no start, ordered fuel pump which was low fuel pressure, and no start, ordered fuel injectors no start, ordered a new ECU programmed for my jeep and no start, then decided to disconnect the camshaft sensor ...jeep starts shuts off in every corner and no power.....decided to pull out the intake manifold to look for cracks and nothing .....decided to disconnect the MAP sensor ....(jeep runs now without map and camshaft sensor.).....it runs and does not shuts off, but no power, just enough to get wife to office ........I AM LOST AND DO NOT KNOW WHAT ELSE TO DO, just received egr valve and new map sensor and will replace today .....but my OBD codes are the following
C121CSTORED/MIL. TORQUE REQUEST SIGNAL DENIED
P0108 MAP SENSOR HIGH(I HAVE IT DISCONECTED)
P0340CAMSHAFTPOSITION SENSOR A (I HAVE IT DISCONECTED)
As i stated before today i will replace EGR and MAP sensor and check compression but if anyone have gone thru this please please please let me know......
forgot to mention that sometimes while running it starts misfiring and i shut off and start and seems to get better.......
Any light on this never ending tunnel will be much appreciated......
Thanks in advance
OR.
Thanks in advance
OR.
