Hi All,
I am trying to troubleshooting an ABS issue on my 2012 Liberty and have not been able to find the exact same symptoms in the other threads I've read through. Here's what's happening...
*ABS/Traction/Service 4w Drive lights are on (sometimes red brake light)
*I have cleared them a number of times, but they return
*Occasionally lights will go out on their own (usually at start up). While they are out the ABS pump will make a shuddering noise (I think the pump, left front?) and brakes will stop poorly... then lights will come on again and car will brake fine (I assume because ABS is no longer kicking in)
*I've replaced both front ABS sensors, but issue remains.
Does anyone know...
*If replacing rear sensors potentially fix this?
*If the shuddering noise points to the pump/module being the issue?
*If I can just disable ABS (and have lights go out and cruise control work again)?
Would appreciate any suggestions. I tried to be as detailed as possible
Thanks, Bryan
Does anyone know...
Thanks, Bryan
