Need Help!! Bandaid alignment until professional one
Dhess5134
I put a 2-1/2" spacer lift on my 2007 KJ (the front was thee biggest pain in the ham wallet!!) none the less its in and looks good. I'm not a huge off roader but def am not affraid to go off the beat'n path. with that said, the alignment on this does not feel good at all driving after the lift, almost feels dangerous. I bought. new lower ball joints and tie rod ends (lets face OE ones suck) I can't get the jeep into my alignment guy until next week but I still have to drive this. I've got a decent amount of mechanical knowlege but am just wondering if theres a basline set after lift that would be ok to drive around on untill my appointment?? lookin at the front of the jeep the tires sit like this \ /
u2slow
BC
Best you can probably do is dial the cam bolts on the lower control arms to "push" the arm outboard.
It was not enough on our 2005. I had to get aftermarket upper control arms. Do get this solved promptly, or you'll wear your front tires crooked like I did.
