Need help with my nuts
WesChapman
N Idaho
What size socket do I need for the big nut on the bottom of the fork looking thingy that connects from the front shock to the lower control arm? Going to attempt changing my springs and shocks this weekend.
Thanks
That's not what she said!
( In TBJ's honor) :D
Check the Franken lift how to for other tips, I'll give a link if you want!
WesChapman
N Idaho
Thanks for the replies.
I'm going to use the strap method and I have the Franken Lift HOW TO: book marked on my garage computer. I have read through it several times. I'm anticipating many things to go wrong, because any project I do always has many things go wrong.
Use two straps one front one rear that way you can pull them in the right amount. If you are not adding too much extra like top plate, clevis etc its pretty easy. If like me you add everything plus 790 springs it takes some to pull it all together
Just take it one step at a time, lay out everything so its not all in a pile. Start with the right side first, its the easiest to do and you'll gain some confidence
Its not hard at all doing a lift
