JohnnyGoneWild
Hello all! First time posting on here..
I discovered a bad ground connection between the engine and chassis. Also the negative cables coming off the battery terminal are very coroded. I figured I would replace the negative to chassis, negative to engine block, and engine to chassis cables. Trouble is I can't find where the negative cable attaches to the engine. Do I get to it above or underneath? I tried following the negative cable down but it gets lost in a web of wires.
Also, anyone who has replaced all the cables have any advice?
Thanks a lot!
Thanks a lot!
