GeekFisher
Hi all,
I am proud new owner of a Jeep Liberty Sport 3.7L with Command-Trac, Track-Loc and 3.73 rear diff.
I will mostly use it for fishing trips with involved a little off-roading. No rock crawling and/or deep mud, just the average trail to given lakes. I do have another subcompact car for every day commuting.
It came with factory 215/75/R16 (Goodyear Wrlanger ST) but this size is hard to find within the tires I'd like to have and they usually cost more. I do have 16x7 aluminium OE wheels.
I'm looking for All-Terrain models with the Three peaks/Snowflake pictogram on as this is a requirement here for winter driving. I have way more choice in the 235/70R16 but wondering about the speedometer/odometer and transmission shift timing ? This is .3 inches taller will this make a difference ?
General Tire Grabber AT2 or BFGoodrich All Terrain KO2 were my first picks and cost more or less the same. I was also wondering about MPGs by going wider and taller as this rig is already kinda gaz guzzler. I should be haulin' either my 4wheeler (around 1000 pounds) or our 12' aluminium boat (which weight like 300 pounds trailer included)
If the difference is not an issue either on speedo/odo/transmission or MPGs, I'd prolly opt for 235s as they have the model I want and I will get a micro tad more ground clearance and winter driving as bonuses.
As a second issue, I was looking for a headunit replacement for the crappy OE radio. I would like to satisfy my geeky side with a full-fledge Android headunit and this implies doing the 2DIN conversion. I was worried that the depth could be insufficient with these units and was also wondering about wiring issues and or cigarette lighter removal issues (as read here)
This is the unit I'd like to install but I'm willing to look at sub-200$ units. I'm not sure if this one includes the GPS antenna...
I am also looking for roof rack as I am often fishing from kayaks which I used to carry on top. I tried online ads for used one but wasn't able to find one. I will probably end up buying the Sportrack SR1009 when it gets on sale at Canadian Tire. Anyone has experience with that rack ?
Thanks,
Thanks,
