PoppaBee68
- Joined
- Mar 18, 2020
- Messages
- 1
- Reaction score
- 0
So I have a 2010 KK Sport. I have a transmission leak problem. I eliminated the cooler lines from the transmission with rubber hoses. There is till a leak that seems to be coming from front of the engine, thought maybe the cooler itself. So I joined the two hoses from the transmission together to cut off flow to make sure it was the cooler. I also joined the two tubes coming out of the cooler as well to prevent the fluid from leaking out. Somehow there is still fluid spraying. How is fluid even making its way to the front of the truck if I have the lines joined? The fluid is making is way down the pour spout near the filter please help if you can...Thanks in advance!
