New user with CRD water leak.
Nikko
UK
Hi guys new user from UK here (been lurking for a while) registered for some info/advice.
I own a 2004, 2.5 CRD which i have owned from new. It has covered about 37000 miles and has been serviced on time by main dealer for 3 years then independent jeep specialist since and it has been very reliable.
Recently i have started noticing a few small damp patched under where i park the Jeep at home an work, the patches only seem to appear if the jeep is parked for a long period so leak cant be too bad.
Last week my coolant level warning light started coming on so i assumed the leak must be coolant so i started having a prod about under the bonnet/hood and noticed that there was water around the area where the top radiator hose connects at the engine side (not to the radiator). The water looked to be coming out from where the pipe attatches to the metal part and leaking down, so i thought the hose clip might be loose so i replaced it with a jubilee clip and went for a short drive.
When i returned home the area was still damp and the water seems to be coming out from what ever it is that the radiator hose connects to, i thoiught that it was the thermosat housing but after some research i think the thermostat housing is at the end of the bottom hose, is this correct? If so what does the top hose connect to? I know the waterpump is there but i was hoping that it was something else (cheaper) and easy to replace.
I know this mis a long first post but any advice will be greatly recieved, i will post pictures if it helps.
Cheers,
Nick.
Nikko
UK
P.S.
Any UK Jeep'ers on can tell me which type of coolant i should be putting in. I know it is not standard Bluecol type but other than that i am lost. I dont want to have to vist the main dealer and pay £££ when halfords do it for half price.
Any one bought it from halfords?
Nikko
UK
Get a proper diagnose on what is leaking exactly.
Any local garage can do that for you, have them put some pressure on the cooling system to check for leaks.
I got the coolant from the local supermarket, get the red stuff. ( for modern aluminium cilinderhead engines ).
Thanks for reply. I have had another look and i can see what is leaking. It is the metal part which the top hose fastens to, also fastened to it are what look like the heater pipes. This in turn then bolts to the engine.
Has enyone got an exploded diagram of this part of the engine/colling system so i can get part no?
Cheers,
Nick.
Nikko
UK
Yup thats the part.
Yes thanks Tony, thats the part that's leaking around the top round part. Looks like i will need a new one (and gasket). Is there anyway to replace it without goning to the dealership?
Nick.
