Oil pump Pressure and timing…
LFX1
So installed an oil pressure gauge so i can visually see pressure readings but what should it be at. I know there is start up pressure and it changes at idle and heat when oil thins from temp.
i get the slight clatter from timing tensioners possibly needing done on start up, loonking to replace those soon but what about oil pump when is eveyone replacing theres just when they do timing stuff while your there or is there a recommended mileage that it starts to fail?
