OME 2inch Lift kit + JBA upper control arms
xeqtr_psm
So far i purchased this OME lift kit https://www.4x4works.co.uk/product/...on-lift-kit-jeep-cherokee-liberty-kj-2001-07/ for my 2006 Liberty 2.8 crd.
Also bought JBA upper control arms.
Question: Can I add separate spacers (front and back) to this kit or should I see what lift I achieve. It says that it should give me +30 / 40 mm but some only get 20mm. I want to retain the OEM tyre size. Just ordered some BF KO2 235/70/r16
You can add a boiler plate and clevis lift at the front and spacers at the back if you want. Did you make sure you got CRD springs? The diesel is a lot heavier and needs different springs.
Kevin.G
I had the full OME kit fitted to my '05 KJ 3.7Lt V6, complete with new shocks, coil springs, and struts. After about 3,000km the height difference has settled down to about 46mm.
