jeepguy4276
It seams like there's a delay. When I downshift it takes a few seconds before it downshifts. Is this delay normal or should it instantly shift? Or does it need to slow to a certain speed before downshifting?
With mine if you were going 65mph down the higway and shifted into 1st the computer won't let it shift down as that would be very very bad, not sure if it's the same on older models.
Why are you manually downshifting it, or if you are going very slow , like off road , then yes a couple of seconds. Hopefully its not out on the highway
