Options for 4 in JBA replacement springs?
JJam2112
Port Angeles, WA
Hey guys I was planning on getting the 4in springs for JBA but he is out and not in making more. What options would I have if I want to get 4in in the rear? I’m currently sitting at 22.5in in the rear full spring lift. I have JBA coilovers in the front so I can adjust them higher, but need help raising the rear. What spring options do I have to get to 4 in?
OME 948, plus two upper isolaters not including the stock one, ( for 3 total uppers )
Then bumpstops ( hockey pucks )
JJam2112
Port Angeles, WA
thanks Tom. Do the upper isolators just stack onto each other fine or do the need to be held together some how?
No that is it
works great with what I told you, have done a bunch of KJs just like that with no issues
jeeptorino68
Oregon
The rear springs visually look a lot like WJ and TJ rear springs. Do you think any of those lift springs might work? The TJ is lighter...so maybe WJ. Has anyone tried it I wonder?
