Output Shaft Bearing
03LibertyLimited
Farmersburg, Indiana
Hey everyone, what I thought was a propeller shaft bearing issue, turns out to be an issue within the transfer case, we think it's the output shaft bearing. Anyone have any experience or anything with swapping this out?
I know it's mostly a dealer only part, but, any guidance is appreciated on how to swap it out or inspect what's going on inside the transfer case.
Porkchop
Troy Mi
I think you can buy a rebuild kit with every thing you will need in it and just do the whole t case .
Porkchop
Troy Mi
Not sure witch t case you have so I checked a couple possibles for your year and I found the master rebuild kits for them.
