max pain
Hi everyone!
Couldn't find any info on what i'm going to ask you... (sorry if i missed something)
About a month or two ago my right headlight started to freak me out. At first the bulbs started to burn out and at last i found the cutoff point (or whatever the thing that clips on the bulb is called) to burn out inside too. I changed it several times, tried to use different bulbs, but in a week or so i had to change something again and again. My mechanic told me, that sometimes this happens and suggested to use less powerful bulbs. At last i came to my machanic once again and had him check the voltage, that came to the bulb and overall voltage, that the car produced. And what did he find out? He showed me, that the generator produced about 14.7 - 15 volts (with normal 13-13.5 as i know). Even when i turned on anything, that consumes electricity, the voltage didn't fall less ,than 14.5. He said that no wonder my bulbs went out so often and that i was lucky nothing else did...
Now as i hear with such kind of sh*t happening i have to fix the cars computer, which tells the generator to produce so much volts. (which is going to be pretty pricy, i guess)
Has anyone had such a problem?
How did you fix it?
How did you fix it?
