Recently bought a '10 KK and just had a P0302 intermittent misfire (2x) . Nothing crazy on scanner snapshot from when it threw the code so figured it's due for coils & plugs (140k on ODO). Ordered and while I am waiting for shipping I swapped two coils to see if misfire moves to another cylinder (not yet). Pulled #2 plug and looks fine - Bosch double iridium which will be replaced w/ stock NKGs - seems illogical but based on forum research I'll try the coppers. In trying to narrow down the issue I measured the rail fuel pressure which was 50 psi when running and upon shut down dropped to 40 psi in a couple of minutes and down to 30 psi w/in 5 min. Leaky injector? Ordered new to replace but I wouldn't a leaky injector leave a wet or carbon fouled plug? Or does this sound like fuel pump (regulator) issue?
Also I have had the hot start issue appear on the car twice since purchased 3 months ago. Could the low fuel pressure and hot start be related? My thoughts are that low pressure could in fact cause true vapor lock in a fuel injected engine?
Any opinions or feedback appreciated.
