Tedd Hankinss
- Joined
- Jan 1, 2020
- Messages
- 2
- Reaction score
- 1
My 2006 Liberty will die at any speed. It shuts down completely and I have to get to a shoulder immediately. After turning the key off, the car re-starts and runs just fine until it happens again. Gap between incidents is random, but never more that 30 miles between times. It seems to be more frequent and has happened about 8 times.
I replaced the CPS with a Mopar unit, and the Crankshaft Sensor (Autozone). I checked the harness and found no obvious problem. I ran the engine and wiggled the harness and connectors looking for this intermittent problem.
The CPS connector had a lot of oil on it dripping from the CPS hole. I cleaned the connector as thoroughly as I could by dousing it with Brakekleen and blowing it out with compressed air.
A couple of times it did not die completely but did that thing others have had where it won't go about 2200 rpm. Unfortunately every posting with that symptom has not been followed up with the solution.
So far it has always re-started after turning the key off for a few seconds and re-starting.
I am thinking of removing the ASD relay and jumping it, but other than checking that relay which I could do by swapping it with the blower relay, I am not sure what that would prove. Since it runs perfectly between occasions, it cannot be the reluctor ring or jumped time.
Any thoughts?
Thanks
Any thoughts?
Thanks
