TwoBobsKJ
So my wife is driving our '03 Libby to work (3.7L, 42RLE, N242 case, 100k miles) and the check engine light comes on. I check the code later that day using the key 3x on/off method and come up with the 0700 code. Took it to the local ****** shop and he tells me the torque converter isn't locking up. "Could be minor, could be time for a rebuild..."
Anyway, I have him drop the pan to do a full fluid flush and filter replacement (we bought the Libby in November and I have no idea when/if the ****** fluid has been changed) and he shows me the shavings in the bottom of the pan - "Yep, gonna need a rebuild soon. It may work for a while but no way that converter is gonna lock up or the light going off."
Driving home from the shop the CE light is still on and no change in the way it's driving, then...
At 45mph I feel a little bump, the CE light goes off and all of a sudden it's driving very smoothly - no 'lugging' or vibrations, downshifts are tighter, upshifts are more crisp. So for the last month or so it has driven fine, I've changed the front and rear diff oil and the transfer case fluid and all seems right with the world.
Question: What should I look out for? Is the 42RLE good for a few more miles? Will my wife get stuck at some intersection with no warning thanks to the ******? Are there any other possibilities for issues from the 0700 code?
TIA for your replies...
