I pulled the Bosch MAP sensor on my CRD to clean today and while it was only lightly coated with soot and oil that I easily cleaned, I noticed that the actual probe is LOOSE...
In other words, I can gently wiggle the probe left and right with a dental pick even though the the plastic center baffle, which is located right next to it, is rigid.
Pics below -- NOTE that for some reason the wiggly probe has a yellow hashmark on it that did not cleanup. You can also see that probe itself is crooked inside the cage housing it.
So my (probably silly) question is --
Is it normal for the probe to lightly and loosely wiggle from side to side??
And also a simple followup request, if someone has a link to a resistance reading or test for the MAP sensor, I could also use that to check if its in working condition.
