What is the best method to remove the lower part of the rear seat? I only found a lever to fold down the seat, but not one to raise the lower part.Under the rear seat, drivers side
You should be able to look under the drivers side rear seat to see if there is a metal box there, which is the amplifier. I have never removed the rear seat, but I found this thread: http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=104&t=70389 Unfortunately the picture links are broken but hopefully the written descriptions help.What is the best method to remove the lower part of the rear seat? I only found a lever to fold down the seat, but not one to raise the lower part.
Unfortunately I didn't see any box, that's why I would like to dismantle the seat. My problem comes from the fact that the radio system drains the battery. I have done several tests, for example disconnecting only the car radio cables but without success, it always runs out of battery. So I thought that the system has an amplifier, and that there is some problem with it. For the moment I solved it by disconnecting the M12 fuse.You should be able to look under the drivers side rear seat to see if there is a metal box there, which is the amplifier. I have never removed the rear seat, but I found this thread: http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=104&t=70389 Unfortunately the picture links are broken but hopefully the written descriptions help.
The passengers side rear seat has room under it for a different metal box, which is the inverter for the AC outlet on the back of the center console (if yours came with one).
