Rear 1/2" Spacers from Boulderbars
604KJ
Vancouver, BC
From Boulderbars;
Towing? Carry a lot of cargo weight? Add the Rear 1/2" Spacers to any of our lifts. $36/pair. They are yellow to match the OME shocks. (Note: Spacers are 10MM)
So I Ordered a pair with my kit, wondering what i do with them though? Where do they go and what is the proper way to put them on?
On My invoice it talks about having to dremel the inner diameter
Note: This Spacer may need to be clearanced for certain Liberties. If the interior dimension (ID) of the spacer is slightly narrow for your Liberty, simple use a dremel to clearance the ID to Fit.
whats that about?
Luke
Interloper
Bancroft, Canada
It goes on top of your rear spring (slips over the isolator that is already there)... I don't know why you would have to dremel it though? Maybe the upper spring perch is a different diameter on some years? Doubt it though.
604KJ
Vancouver, BC
i think i got it figured out, boulderbars just sent me this;
Only some Liberties require using a dremel to the inside (very few need this done, so just test fit them and if they look a little tight on the interior diameter, then just use the dremel to clearance them as needed).
REAR LIFT SPACER APPROX. 1/2"
2002-2007 LIBERTY KJ
Includes: 1 each rear spacer
INSTALLATION DIRECTIONS
Step 1: Remove rear spring then remove upper factory spring pad from upper spring mount.
Step 2: Install 1/2" spacer into upper spring mount.
Step 3: Reinstall upper factory spring pad below 1/2" spacer.
Step 4: Reinstall spring.
