Rear speed sensor
Raybird2112
I have a 2006 Jeep liberty sport and I am getting all the lights lto light up on the dash for a few minutes then go back to normal. I am getting a c1020 code, I believe. I replaced the left speed sensor with an mopar brand, drovit for 70 miles, and the same thing happens. Should I replace the electrical connector next or is it the bearing?
blackhawk
Venezuela
Check if you get 12 volts on that left rear connector with switch on....if you get it, shake the connector to see if there is a bad contact...
Ksat
ny
Bring your vehicle to a few different auto parts stores and have them scan for codes. There may be wheel sensor code that will point you in the right direction.
