So the bulb is a 3757....and I plan to get that tomorrow...my main question is:
Are there any tips on removing the tail light? I removed the torx screws, and it budged only a bit. Any tips?
TIA
The tail light has what are called 'ball studs' in it. I am not a subscriber to the 'pull harder, not smarter' philosophy on anything, but this is a rare case where you need to do exactly this.
Unscrew the torx screws, put them aside. Your taillight will be 'loose and wobbly' but won't come off. From here, grab hold of it firmly and pull back-- it takes a fair amount of force and strength, but it will eventually pop off. And yes, as it pops off it will sound ugly-- like cracking plastic.
The next time you pull it off it should be easier. The ball stud inserts kind of 'wear' a little bit each time you pull it off. My Chiltons manual even indicates that you may have to replace the ball studs everytime you remove the taillight. I've only replaced one side taillight and the ball studs weren't quite as tight after putting it back on. Personally, I take a negative view of the ball stud concept on a taillight, but someone can probably dig up a good reason why they use them.
