So I've been working on my transmission replacement and starting to pull the various parts required to remove the trans. And I'm currently stuck as I cant seem to get the drive shaft loose. In the service manual it indicates that on the diff end there should be bolts clamping down the diff side of the universal join pin, however mine does not have these. So I made the assumption that I had to remove the 4 bolts holding the diff end of the shaft from the flare on the front of the diff drive shaft. After doing this I still can not get the shaft to come loose from the plate. Any pointers on this?
Tom
Tom
