Removing trim below windshield?
clapperc
Blair County, PA
Reminder: 2007 new to me. I have a squeak on the driver's side just below the windshield. How do I remove the trim piece between the dash and the windshield? Thanks!
mag03kj
LOST
Remove both "OH ****" handles and then just take a flat head to pop it up!!
clapperc
Blair County, PA
Removing trim below windshield? - THE TOOL?
Thanks for the advice but... My sockets/nut-drivers won't fit in the hole to get to the screw! Suggestions?
jimkelly
Make sure you use 1/4" drive sockets
I just had my pillar covers off to fix a blocked sun roof drain line and then again for routing my cb wires. I forget the exact size socket but its a tight fit, just make sure you use a 1/4" drive socket in the correct size ( the size escapes me right now). If it matters i was using a craftsman set.
clapperc
Blair County, PA
It seems I didn't have the correct size tool/socket. So... I had the dealership remove the pillar cover today. No TSB's. Now the search begins for that pesky squeek in the dash!
