RPM's Stay's a bit high until fully stopped
Sometimes the rpm's stay up around 900-1200 while braking at 10mph downward especially when cold, not as bad when hot.
Cleaned the throttle body and is better, but still what controls the rpm's and are they adjustable?
Feels like KJ is still being pushed forward while braking, (tried Neutral still up for a few seconds) should it not be lower?SHOCKED.gif
I have also noticed that while I am trying to warm it in Neutral, that I can loose 400+ RPM when compressor kicks in..I take it there is no auto adjustment to up the rpm's when compressor kicks in.:( hmmm....
ya ok so....Tips please on removal and cleaning...or replace?....
Just two screws and no spring? Must replace the o ring if removed? or can this unit be cleaned and stuck back in..best cleaner?
Prospect62
New Hartford, NY
I'm having the same problem...even after having my engine replaced. That bill must not have included a new IAC.
LI02liberty
Long island
If you clean it or replace it just make sure you clean the two ports that it sits in on the throtle body. Mine both had a ton of carbon in them.
Thanks for that, I will just spray some carb cleaner on a small brush or something,will know what to do once the IAC is off. Thanks!
Porkchop
Troy Mi
Had Iac do this and showed good on the computer. Tryed one of well known quality and bing go worked.
AlexKJ
Earthquakeland
Same problem here... I recently get the TB cleaned though...
Easier to just replace, there cheap and get OEM only.
eeerrr... Not an option for me... over here the Air Idle Speed Motor (P/N 53030840) costs USD 172.22... Better cleaning it up :D
AlexKJ
Earthquakeland
Yesterday I tried to clean the IAC
Yesterday I tried to clean the IAC. I disconnected the battery, pulled the plug from the IAC and took off 2 Torx screws. The result was a plastic black piece in my hands and something like a tab remanined in the throttle body.
I tried to turn the tab, but it wasn't budge... I was too afraid to do it harder nevertheless.
Then I proceed to spray contact cleaner on the plastic part and WD-40 on the tab... then I cleaned and reassemble...
Any comments?
kb0nly
Planet Earth
Any comments?
You sure you removed the IAC? The TPS, Throttle Position Sensor and IAC are on the drivers side of the throttle body. The IAC is the bottom or lower one.
From what your describing it sounds like you removed the TPS.
Here is what the IAC looks like, its like a plunger that goes into a bore.
Well when the ports and the IAC itself get carboned up it puts alot of stress on the IAC motor,which can damage it and strip the gears a little.So just cleaning it may not(almost all the times from experience from cheap customers) fix anything.
AlexKJ
Earthquakeland
Mmmm... maybe it was the TPS :p ... I'll check again later...
Something about the cleaning method?
kb0nly
Planet Earth
I agree with tjkj... Cleaning it really isn't likely to fix it, its worth a shot for free, but you better plan on buying a replacement.
Can anyone look to see when cold and you first start the kJ, what is the rpm reading?
Mine seems to be about 1000 in Neutral and takes a few minutes to get down to around 650rpm. Is this Normal?
