bigBlue
I will be giving RRO UCA's a score out of 5 (5 being the best score) for a few categories. First off I want to say that this product could be awesome....if the distributor would have included any instructions at all, and the engineer would have actually had knowledge of the KJ's anatomy.
Customer service=5. RRO responds with in 24 hrs to questions (even on weekends)
Install difficulty=3. Having the right tools makes this project so much easier. proper deep well sockets in 18 metric (good luck) are needed with about 12-18" of extension...and small hands.
Engineering=1. The bushing zerk fittings for greasing are practically unserviceable once installed. Ive been to 3 shops and they all said that this design was horrible and that they cannot get to the fitting to grease it.
Directions= 0....there were none
Overall rating= 3 out of 5
If you take a hammer and bang out some room on the top of the body mounts to allow the zerk fitting to travel w/o rubbing....
If you grease the bushings FIRST before you install the UCA's....
Then I would give this product a 4.5/5.
But right now as it stands....the unserviceable bushings are worthless and I cant rate this higher than a 3/5
