Run-cool
WickedBruce
San Antonio TX
Would it be beneficial to install run-cool hood louvers in reverse over top of the airbox and then find a way to seal it when the hood is closed?
ridenby
Gold Supporter
Kentucky
If you are looking at TRUE cold air intake,I think you are on the right track. Not sure about louvers/scoop that far forward as water from rain/puddles/fording tends be pretty heavy at the nose. Have thought a scoop and intake closer to the cowl would provide clean/cool air.
WickedBruce
San Antonio TX
I was on the run-cool site and there was a guy that did it for his jeep, and it didnt seem like a bad idea...but i was thinking the same thing that you stated. Not sure if maybe i could put a pre-filter or something in
Towards the back of the hood / cowl area maybe but I wouldn't up front
Although I run a 3.5 inch hose from the grill into the airbox and I get very little if any moisture during hard rains
Plus having it right over top of the airbox you'd still have to find a way to direct it to the bottom of the box
rockymountain
Spencerville, IN
I thought the louvers were just to let heat escape the engine bay.
Ha, nevermind the coffee just started working. :freak3:
