Rust from the inside
Dr. Pluh
Hello, i noticed some rust bubbles on the body panel next to the rear wheel (2006 KJ). They were likely caused by water seeping through from the other, probably rusted, side.
I sanded it down, applied wd40 and clearcoat. I also poked little holes through to spray some wd40 inside the panel.
But i'd like to get my hand in there so that i can remove rust and apply a proper coating from the inside. Is there any way to do it? What do i need to remove?
