Ok got the lift installed right away you can notice the height difference...while installing the shocks the instructions that i got said "install the new shocks. The washers supplied with the kit will be used as shims since the new shocks aren't wide enough at the attchment points. " however no washers were included at all with the kit. After i took it for a test drive i noticed almost a like a knocking noise coming from the rear every time i went over any bump would that noise be the shocks "wiggling back and forth" since the washers were not put on?
thanks
thanks
