sas calibration
Chuck 172
I have a 2011 liberty. I replaced the clock spring. Getting code U0126.
How can I re-calibrate the steering angle sensor?
The 08 repair manual is not helpful here. It says the SAS is part of the clockspring, and that it is self calibrating and does not require calibration as long as the new clockspring was installed with the wheels positioned straight ahead.
I'm pulling this from foggy memory, from when I had to do a re-cal on an SAS for a jeep here, based on what my scan tool told me to do...
in a large parking lot with the engine running...
turn the wheel clockwise to lock
turn the wheel counterclockwise to lock
center the wheel
drive straight ahead for about 50'
make a right hand 360* loop
make a left hand 360*
turn off the vehicle
turn on and start the vehicle
not all the steps will be required, if the system is satisfied at some point during the process.
you should hear a chime when it's all happy and the dash emojis should go off.
