Seized upper control arm bolt. Attempt to remove it myself, or admit defeat and take it to a garage?
jamesbeat
New York
I am trying to replace the passenger side upper control arm on my 2005 Liberty.
I have done the driver's side one before, so the passenger side seemed like it should be easy in comparison, because the bolts are much easier to access.
I removed the nuts from both bolts, and got the front bolt out easily, but I can't get the rear one to shift at all.
It appears that what has happened is that the bolt has become seized inside the inner sleeve of the rubber bushing. I can move the control arm up and down, but it is very stiff, and I can feel that the inner bushing is staying still as the rubber part moves around it. The bolt rotates a few degrees as I do this.
I have tried all sorts of things, but I can't get it to move with the tools I have. I don't have a torch or an air hammer etc. I do have an angle grinder, but it's too large fit in the small pocket that the control arm ends sit in.
I'm thinking I could buy a sawzall and cut down either side of the bolt from inside the wheel arch, but it's possible I might end up just damaging it, and then I won't be able to drive the Jeep to a garage safely.
So, is a sawzall pretty much guaranteed to work, or should I just drive it to a garage and have an expert take over?
Jeremy-WI
Home
A sawzall will work but you will be bloody. The stroke on the sawzall I had was a bit long for the space on top of the blades being longer than I wanted. I lost count of the blades I destroyed doing the drivers side rear bolt. The passenger side freed up after a good soaking in penetrating oil but the rear on the drivers side put up a fight. A 3/4" board attached to the sawzall shoe might help with the stroke length as I finally used a piece of 3/4" hose.
