On a 02 Liberty Selec-trac with a limited slip rear differential in part time 4wd:
1. Is the rear diff locked in partial 4wd so the limited slip does not matter or does the limited slip diff still distribute power between the two rear wheels?
2. Will the front wheels get even power in part time 4wd or will a spinning front wheel get more power like a rear diff in a simple 2wd system.
This site https://www.jeep.com/4x4/loader.swf says that in partial 4wd all four tires get traction which implies that both the center and the rear and front differentials lock. Is this true?
