Sensor issues
Cbach
2005 Jeep liberty 3.7L. Been chasing a P0344 code for a little over a year now. Last year I replaced the camshaft position sensor with a non mopar one. Then I had a shop replace the connector and the 3 wires going into the connector and still had the code intermittently coming back. Today I finally changed the sensor to an actual mopar sensor. Prior to installing the new one I cleared the code. After installing the new one I tried to start the car and it gave me the usual hard start which took 2 tries. Once the car was the running the code came back. So I turned it off cleared the code, started the car and it seemed fine. What’s the next steps if the code continues to come back?
blackhawk
Venezuela
See the code chart for P0344 attached
from my personal experience, i had to change both CPS and CKS for this code to resolve. Aftermarket sensors seems to be tad longer which would cause issues.
I doubt multiple sensors are faulty, have you checked the plug and wiring?
GnomeKing
Vancouver, BC, Canada
I mean, it runs without issues most of the time- I’m getting P0344 either right after start or within first couple of minutes of driving, clear it and the. I can drive for hours without issue OR on heavy/fully throttle acceleration. I have ordered new connector pigtail bc old one was soaked with oil, replacing will be fun tho. If it was only on full throttle, I could imagine the torque tugging on the connector/wiring maybe? Not sure right after start tho. Didn’t have the issue before replacing the sensor.
