Patrick McGrinder
- Joined
- Feb 12, 2021
- Messages
- 56
- Reaction score
- 22
2007 Jeep Liberty, I had to replace the wiring / connectors for the MAP and the coolant temp sensor. I had to remove the serpentine belt and move the alternator to replace map sensor. All seemed well at first but now the car is hard to start takes 3 to 4 cranks to start and I had a slight squeaking noise when turning steering wheel before I did the map sensor but now the squeaking noise is very loud. The serpentine belt is tight with no pull to it but I can twist the belt. Power steering fluid is fine and the car runs fine, can the serpentine belt be to tight ? Can I adjust the tension on belt ? Thanks
