Shift in park but in reverse
Pt420
Replaced shifting solenoid pack on my 2007 Jeep liberty after replacing I have no parking gear now. Parks is reverse, natural is in reverse and natural is in drive and so forth. I can put it in the spot for natural and start the car sometimes will start in park but it is in reverse. I went down my lane in reverse and back up it in drive so don't know if I am in second when in drive because drive is in natural. Did not take out on the road to test because of this. I had this problem once before when I disconnected the cable to do other work, all I had to do than was disconnect again and manually shift it to park and connect it again. That is not working this time. What might be going on. Thank you
blackhawk
Venezuela
I also think it's the cable tension. It must be tied. You can try to move it with your hands to check if it's kind of loose
