I'm talking about those modules that "fool" the radio into thinking a CD changer is present.
Hmmm, when I installed my RF adapter I didn't need any special adapters for the antenna line. I posted about this in another thread, I'll go find it and post a link here in a few minutes...
OK, here's what I found when I went out to look in my mother's '05:
Pull up the trim at the bottom of the door (green outline) and remove the passenger side kick panel (yellow)
Next remove the two screws indicated
Then pull the plastic panel down. You'll see a long metal junction in the antenna cable
You can separate these two sections. Plug the green half into the FM modulator and plug the wire with a similar end from the modulator into the yellow half
Now run the thin connector wire up to your Sirius radio and you're ready to go. This is the same method I used to attach the modulator to the stereo in my '03.
RF Module = translates the signal from the satellite radio into a standard FM signal so that your radio can decode it. Yes you'll still be able to use your standard radio and CD player; the RF module is only active when it receives a signal from the sat radio (when the sat radio is turned on).so heres a couples stupid questions, but what exactly is a RF Module, Will I still be able to use my radio, and does is the imput a standard 3.5mm jack.
