skid plates
sydbro
Sykesville Md
I ordered some mopar skid plates for my 02 lib and just received them yesterday. I soon realized that they dont fit the bolt pattern. After calling to find whats up, they told me that they were mistaken and that there is no such thing as mopar ****** and transfer case skid plates. Is this true? If so I guess I am screwed, if not, please let me know where I can get them
Thanks guys
Thanks guys
They just don't fit the '02 KJ,you need to modify them to make them work,at least for the ****** skid but the t-case skid should bolt right up.
You can get SkidRow skid plates,pricy but way better then the MOPAR ones.
I believe three of the four bolts will line up on the tcase skid.
****** skid needs to be modified alittle to clear the exhaust and you will need to drill holes for the back two bolts. There are a few threads around about it all.
Are any of the Mopar skids good. I know there is better I'm looking to get skids eventually and want some guidance.
They are 'ok.' The mopar ****** skid is probably the weakest one but it will do ok if you slide over things and do not HIT real hard. Ive seen them bend pretty easy though. The front skid is pretty good while the tcase and gas tank are just par.
