SYMPTOM/CONDITION:
The vehicle operator may experience excessive wind noise with the sunroof in the closed
position or excessive wind noise with the sunroof in the closed position and loss of “Auto
Mode” when operating Sky Slider sunroof. On vehicles built prior to January 16, 2008 Wind
noise can be caused by closing roof at speeds above 60 MPH (96 KMH).
NOTE: Export vehicles will not auto-close or auto-open while the ignition key is in
the accessory position.
DIAGNOSIS:
If the vehicle operator experiences the Symptom/Condition, perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1(AR) 68038578AA Grease, Nyogel 729F - 50 Gram Tube
One tube will service four vehicles
1 68057092AB Header Bow Kit, Front
23-003-10 -2-
SPECIAL TOOLS/EQUIPMENT REQUIRED:
NPN Battery Charger
CH9401 StarSCAN® Tool
CH9404D StarSCAN® Vehicle Cable
CH9409 StarSCAN® Documentation Kit
CH9410 StarSCAN® Ethernet Cable, 12 ft.
CH9412 StarSCAN® Software Update Device Kit
TechCONNECT PC or equivalent
NPN 1/8” x 4” ID Tubing
NPN Electric Drill and 7.5 mm (19/64 in) Drill Bit
