jeepguy4276
My heat doesn't really work but the cooling system is all good. I've heard that others have had this issue and it's the blend door. Do how do you fix it? Is it hard? I'm wondering when I want to tackle it.
If you have to replace the blend door the whole dash has to come out to access the HVAC box and the HVAC box also has to to be removed from the KJ.You also have to have the AC evac'd,then recharged when all done.
Book time calls for like 7.5 hours not including the AC evac and recharge.
Maybe an off-the-wall idea, but I wonder if it might work to set up a closed loop and let it circulate a good flushing solution for hours or even a day or two. I'm thinking of how parts washers can clean up stuff over time that you'd have a hard time cleaning any other way. Think Colorado River style cleanup.
