joshgoble
Setting on 37x13.5x 17
I'm trying to figure out if replacing the ATF fluid after water was introduced to the system will correct the issues of the lock up converter solenoid sticking and the fact that third gear and reverse no longer engage and no overdrive. Or is it one of those things where I am going to have to replace the valve body solenoid and most likely the clutches?
