land_shark
- Joined
- Dec 17, 2007
- Messages
- 12
- Reaction score
- 0
I started feeling vibrations throughout my '05 3.7L when I slowed down as I rolled into Colorado Springs a month ago. I checked my tire pressure and found it had shot up to 55+psi (quite an altitude change from 700' here in Iowa). I had been fighting a crosswind the entire trip out, so I assumed I was experiencing the effects of some pretty severe cupping.
I adjusted the pressure, rotated the tires, and still felt the vibes. The problem was, they weren't happening all the time. It was only after I'd been driving a bit. I checked for play in the wheel bearings as well, and found nothing strange.
Took it to a great local shop (Lovetinsky's in Iowa City) and they found that the Ujoint to the rear differential was shot. 2 of the knuckles were completely dry and had fused. They installed a new joint (which has grease points), and it's good as new.
Thought you all might be interested. hope this helps.
Jason
Jason
